Windows Audio channels 1.9 firmware
I am demoing a unit in hopes that it will do everything we need. I noticed I can add L-R audio from windows to the Qu-32 as audio streaming and I can send it to whatever channels I like. We use a program called Show Cue, similar to Q-Lab, and I can get 2 channel audio out from it for running our shows, but I can’t figure out, if it’s even an option, to have surround, ie Back-L, Back-R coming out of the windows driver as well.
Is the Windows USB streaming driver 2 channel only?
Are there ways to get surround coming from a PC, is it Mac only if at all?
Via the USB-B port you should be able to stream as many channels as you need.
Supposedly 32 X 32 channels
In SCS, see if changing the audio driver (e.g. from ASIO to Direct Sound) will make any difference. You can find that in the Editor window under Production Properties>Audio Devices.
