yes.
midi map for Qu Reaper & PC
can not get that to you for couple days tho.
Dave nz
yes.
Dave nz
This has been working for many years in the Yamaha DM100 and DM2000 mixers.
I used a Windows XP Pro and used MADI cards and usb Mackie Control protocol ind it was flawless.
I ran Nuendo with it.
It would be a great additional implementation
QU-16/24/32 as DAW controller for Sonar in Windows. This works perfectly and bidirectional.
I would also like to see improved support for Windows. A&H should just do the same as on Mac, write a small DAW Control application with support of Mackie Control and HUI.
In Windows the ASIO driver is not working if you don’t turn on PC and QU in correct order (which remembers me of Windows 9x days and older hardware), MIDI is not really supported (or at least not as comfortable as on Mac). Even if Mac is used more often for DAW, there are plenty of Windows users out here. So please A&H, invest some money and make us Windows users happy (as you just did for Android ![]()
So sad, i regret buying QU-32. No DAW control for windows, from version 1.8 no more support of iOS 5.
As mentioned frequently: DAW control only provides a quick way to control faders and mutes. If you want to have serious, bidirectional remote control between the Qu and your DAW you’ll need to use the native Qu MIDI protocol anyway which is available on both Windows and Mac.
Qu24 + Pro Tools 10.3.7 + Windows 7 (64bits) + Bome Translator.
I was able to route 24 faders from Qu to DAW and DAW to Qu. Mute buttons and PAFL also work.
Configured 2 soft keys as Bank Up & Bank Dwn and I can control all channels in my DAW from my Qu24.
Thanks for all who posted any comment here. I’ll continue to extend the functions and later share de template so all windows users can set up their qu product in a reasonable time (about 5mins).
Best regards from Argentina.
Greetings from NZ to Argintina ![]()
Wonderful.
Look forward to your Windows 7 bi-directional template
Please keep us all in that loop
Cheers
Any news on this?
So I finally decided to sit down after a year and half of owning this thing and decided to setup my DAW CONTROL via windows 8.1. Wow I wish I’d set this up sooner. This is tight. Although I did not get the PAN working for each separate channel. Has anyone got this working? I’ll continue to test when I get a chance, But to those of you who didn’t think it could be done. Well here is the proof that it can be done. Love the way the faders follow the automation within Cubase. Check out my video below.
Hello everyone. I’ve been with tight schedules latetly. I haven’t shared anything yet as I’m debugin a problem wich is:
Everything involved on controling QU->DAW and DAW->QU runs smooth. But, while streaming USB data from PTools 10/12 FX return#1 fader will for some reason be responding to DAW while it shouldn’t. As far as I understand Qu uses 2 different midi signals.
Midi for Qu Pad and Midi for DAW control. Therefore I understand it must be a problem of crossed coding in between both things.
Please, bare with me, I’ll share the data once everything runs smooth and tests ok!
Abrazo from Argentina!
