I connect a short cat5 cabel between ACE and Lan on the router, its a Belkin Play N600 DB. I also connect it the same way from the Mixrack. The routers I use is the same.
I tried the IP settings from the manual and I´ve also tried these.
Maybe I got it all wrong… do I really have to use cat5 cabel between my surface and mixrack.
Yes you must use a cable to connect surface to a mixrack!..Connect Ace port from surface to Ace port on mixrack then, from either unit use a network port to connect to the router …Ace is used for audio and control! so it should not be connected to a lan’s network port , only from Ace to Ace ports.
No its not possible because of the wireless bandwidth required for multichannel AUDIO. Both the iPad and Editor software can be wireless because they don’t have any audio being sent or received. The iLive surfaces have local audio inputs and outputs plus PAFL busses and all that audio plus the control and metering signals requires more bandwidth than is currently achievable over wireless networks - not to mention reliability issues!
Cheers
Richard Howey
Audio Dynamite Ltd
Well, I wouldn’t say it’s not possible to connect mixrack and surface via wireless system. It just have to be way more serious than wi-fi. There are certain products in market that are able to provide stable hi speed communication. Price easily can exceed all iLive system, that is a downside of this story.
Little bit cheaper would be to go with laser link if cable is not an option.
