XDR-16 Issue
I just recently got an XDR-16 to add to my system and it is not finding the setup web page in the internal server. I have to set it up that way because of an existing network on the .1.1 network. All my ilive stuff is on .0.1. I connected just my laptop and it definitely sees the XDR on 192.168.1.20 because I get a message that says “iDRLive HTTP Server Error” Not Found. It’s almost as if the internal web server never got flashed… Can someone help me with this?
thanks,
Steve
Can you connect with the editor to XDR 192.168.1.20 ? of course you have to set your laptop in the same range 192.168.1.x , x= 10 for example.
Lieven
T112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver
Hi Attreui
I think the problem may be that you have not used the correct capitalization in the address bar. You need to use a capital ‘S’ in Setup as shown below.
192.168.1.20/Setup.html
Hope that helps
Regards
Sam A&H
Wow, a case sensitive URL. Who would have thunk? Thanks Sam, that did the trick.
