xDR Routing
Hi fellas,
Just wanted to see if I’m clear on something.
xDR ACE connects to PortB ACE on iDR48.
xDR PortB with Dante can output 64 outputs from any routing in console. correct?
But only 16 inputs, regardless whether I actually use the 16 from the xDR or not, correct?
Thanks in advance.
Gil
Gil Parente
Design & Integration
Entertainment Arts, Inc.
Hi Gil
This is correct. Please also bear in mind that one (configurable) block of 8 channels from the 64 you are sending to the Dante card will also be sent to the xDR-16 XLR outputs.
Cheers
  • Jeff, A&H
