Xone:96 - Record send returns
Hi
Is it possible to record through USB the audio that is coming into the return channels, meaning the audio that has been processed by my pedals? I seem to be only able to record and capture on my computer the audio that is sent out (before the effects).
regards
Frímann
see page 44
The block diagram looks like you can send the returns via mix 1 mix 2 or LR but not usb
unless there is some way to connect one of those mixes to the usb
I admit the diagram is hard to read and should have a matrix that shows in/out combinations more easily
you could try to blow it up and see if you could trace a path to the usb from the returns
