Hi everyone,
I found a strange bug using my mixer, apparently, if you turn on BitBash OR BitBash2 effect on any channel with analog switch (ana) it has a leak. The effeect produces sound even though there is apsolutely nothing being played on it, and the channel is regler is all the way down.
Is this expected by design, or is this a bug on specifically my device?
There is nothing on effects settings that can be changed.
For testing purposes simly turn on 1 or the other effect on FX-X or FX-Y, put all knobs on middle,“default” settings, and switch the xfade/fx on either X/Y, witg channel being set up to use ana input, instead of usb/dig. Turn the volume up, and you should hear the effect bashing.
