Xone:K3 myCatnip's script for Mixxx, full RGB sysex, and color Lab
IMPORTANT: phrasing starts from intro-start marker, forgot to mention in video (amongst other things). Currently extending phrasing functionality so specific cue color markers can be used purely for phrasing resets without being activated (currently only supports this if activating specific color cues).
Current video is already out of date. Will make new quick intro video going over features/use case but not what all controls do, that’s covered in docs fully anyway.
PHRASING NO LONGER USES INTRO START MARKER!
Now you use hotcues with special color to set phrase markers.
Set the color in xone-k3-cat-schemes.js default is the white mixxx marker: XoneK3.PHRASE_MARKER_COLORS = [0xF2F2FF]; Can add multiple colours.
Phrase is synced to last phrase-setting-colored marker in time line and extends as expected to the left of the first marker if you are before any phrase marker.
-it is now set by Mixxx default color scheme white cue color cues.
FOR THIS PURPOSE: The script also has chord + slip in CUE layer → overlay hotcues 9-16, being set in that mixxx color colour.
Also you can get indication either pulsing or constant color. You can also get indication when not playing. Default is pulse when playing flat color when not, but both can be edited or set to off.
Huge docs and readability passes, removed odd_loop, now its an overlay you access with chord + slip but in LOOP layer.
Stripped out most rate limiting after realising it’s not actually needed and what i thought it could help with is not bulletproof; it just makes it a lot rarer. One beat jump throttle in loops only now.
Video is partly outdated. Layout now fully settled.
hotcue916 now hotcue2, top row as before, bottom row intro outro markers instead.
phrase markers must be 9-12 as set in the overlay (can tune to anything you want, 4 is plenty and less performance impact for slow devices so that’s the default).
Extensive performance optimization and hardening has gone on.
I will make new concise video on the slightly more consistent-across-modess setup and new overlays and the phrase marking.
Will be quick overview not list of all controls. The readme has all controls anyway.
