Hi there
I have an A&H ZED 14, I also have a rack comp and a rack reverb, I use my mixer with a live band, I want to use the two effect units for the main vocal only, how do I connect these up?
Thank you
Hi there
Thank you
Each XLR input channel has an INSERT jack (Tip=Send, Ring=Return) that you can use to insert the compressor.
The reverb I would send to AUX OUT 3 or 4 (post-fader) and return it via a free ST IN (1-4).
Thanks, that works great, is there a way to utilise the main insert points (next to the main outs L and R) to connect an EQ unit so that it effects all channels?
Yes, of course are “INSERT L + R” intended to insert something into L + R in order to effects the main mix.
Btw.: If you couldn’t find the somewhat hidden user guide on the A&H website, here it is:
