ZED 24 send/return question
I might have missunderstood the manual, so please help:
I am trying to add a stereo effect module to Stereo track 3, and then send any tracks to aux 3 so the signal would be processed. However, when i send two channels into Aux 3, I only hear one (left) channel comming out of the aux. I had stereo to two mono jacks cable patched into aux 3, connected to left/right of the effect module. Am I assuming aux 3 is stereo, while it is actually mono?
I realise now that auxes are mono. So if i want to send stereo info to the effect, I will need to use both aux 3 and 4, correct?
Yes the auxes are all mono balanced line, your “stereo” break put cable
was was only giving you the + and - of the balanced line output.
To send stereo into an FX unit you would need to use to post fade auxes.
With my analog boards I always sent mono to FX units but returned them
in stereo to the board.
Cheers!
Yeah IDK why I thought aux would be stereo. lol. I have a binaural synth and wanted to pay around with sides from return, thats why i did it like so. hanks again.
