I am using (setup 1, see below) audio is sometimes glitching when I playback audio through my motherboard audio while the ZEDi is hooked up.
You can hear it here: Dropbox
I should add that sometimes the distortion happens when playing through the ZEDi as well. Everything seems to go well if I don’t have both interfaces activated in ASIO4ALL.
The attached image shows my ASIO configuration.
It’s a little hard to predict when this distortion will appear or not. Sometimes if I switch back and forth between onboard audio and ZEDi audio, it stops.
I’m also having a similar problem with my other setup, which uses an older Echo Layla24 and this ZEDi. With this setup, the distortion tends to start a while after I have Ableton running.
Is it a timing issue with ASIO?
Setup 1:
Ableton 11
Motherboard: Gigabyte 78LMT-USB3 R2 , using onboard audio optical output
Windows 11
ZEDi 10FX
