zoom sound to QU-24
My issue is that no sound is coming from ZOOM to my A&H QU24 even though all other computer sound is working fine. I get sound from other outputs like the built-in speakers or my monitor’s speaker but obviously not ideal when video sharing audio projects.
I am in the zoom audio preferences to set this up as default given that I encountered problems during my last zoom conf…
when I press the “test speaker” button no sound is coming through.
Any advices at all?
Did you go to the IO set up menu in the preamp section on the QU and select USB on the proper inputs.
Thank you for your reply Mike. I did. As I mentionned I get sound out from other sources (Logic, Itune, Youtube etc)
If your using the USB B connection on the back of the mixer I think
it’s a matter of finding out what tracks/channels your outputting on ZOOM
and then set the board inputs as needed.
Thank you Mike! Kowing ZOOM’s output is defaulted to 1&2 helps obviously…I am using soundflowerded to enable me sending through to my usual 29/30(ST3) computer output.
You should be able to bring it in on channels 1 & 2 then.
