1.5 bug/strange behavior FX Library
Hi guys, Hi Alex,
I´m on 1.5 and found something to be strange. I´m on the FX screen and want to insert a new effect type to a slot. When I´m choosing one from the left column (Reverbs, Delays, Modulators, etc. and nothing from the middle column (Arena 1, Arena 2, etc), hit then recall, the last inserted FX preset will be loaded. When BEWARE Infra is the last loaded preset, it will be loaded into the next slot, no matter if I click on reverb, delay, etc. and recall it without choosing a specific preset.
Wouldn´t it be good (instantly start singing in my head :slight_smile: ) if there was some kind of Default Effect. Or nothing?
Should the recall button be grayed out, when I´m opening the library and only turn green, when I made a decision and clicked on a preset?
Or is it a feature?
Cheers
this is wanted behavior
all libraries work that way
on all A&H consoles
makes it easier to deploy compressor models over many channels for example
Check! Thank You, Steffen
