2 GLD with a set of audioracks
Hello there.
It is possible to “split” the signal from a audiorack to 2 different consoles?
I was thinking about having a network switch (1000Mbps) and plug an AB168 and an AR2412. Then plug 2 GLD to the switch.
Would this work?
Cheers!
Works but you have a clocking issue. You will hear ticks and gliches.
Hi Ludwig,
No, this is not a supported setup. You can connect the AudioRacks to one GLD system, and share audio with a second GLD system by fitting both consoles with an ACE, Dante, MADI, EtherSound or Waves SG option card.
