2 SQ, 1 GX4816, s-Link question
Hi everyone,
I know this has been slightly covered but I can’t see anyone asking this specific question.
What I want to achieve is the following:
GX4816 at Mons connected to 2*DX168 on stage
SQ6 at Mons with Waves card (for Waves and record)
SQ5 at FOH with Waves card (for Waves and record)
It’s my understanding that there is no way to do that, as Mons has to have an SLink card to connect two desks to the same GX. Is there a way to do this? Can you connect some kind of switch to the SLink line?
Any insight would be appreciated!
You can pass audio between the two desks using the Waves cards (or via Dante cards installed in each console if you needed to use Dante instead of Waves).
So your monitor desk will have the GX4816 (with the DX168s connected) connected to the built in SLink port. You’ll likely have a local computer running Waves, but you will also need to connect to the FOH Waves card as well. You will need to use the routing tabs on each console to properly route the needed I/O between the consoles.
Ah yes, I hadn’t thought about linking the Waves cards. That would mean I could use those Waves tie lines from Mons to FOH as record inputs too, then the remaining channels of the 64x64 stream can be used for plugin send/returns. Can I use 64x64 at 96k?
Does this mean I will need Waves approved switches at Mons and FOH to be able to have computers at each end on the same network to pick up those tie lines?
That would mean I could use those Waves tie lines from Mons to FOH as record inputs too, then the remaining channels of the 64×64 stream can be used for plugin send/returns.
That is exactly what I was thinking. So if you max out the console at 48 channels, you would still have 16 sends and returns for plugin use. If you need less channels, you’ll have more sends and returns available.
Can I use 64×64 at 96k?
Yes, the SQ Waves card runs 64x64 at either 96k or 48k. There is no difference in I/O capacity between the two choices.
I think given the number of Waves connections you are going to need to make and the limited number of Waves ports available, you are definitely going to need to use some sort of network switch that is known to work well with Waves.
Thanks Brian!
