I’ve only recorded to the USB pen drive so far, I was planning to use the multi and was curious as to the location of a 48/96 toggle?
This would be a stand alone recording, no DAW involved.
If you add more than 16 tracks, does it default to 48khz?
Is there a toggle?
Have I missed it???
Toggle (Sample rate) is under CONFIG - USB/SD/Bluetooth.
No idea if sample rate is automatically downgraded when more than 16 channels recorded. Most likely it is.
Thanks Juha???
If you select 48khz the app will let you select more than 16 channels, whereas if you go with 96khz you physically cannot select more than 16 channels.
