a 16 track recording for practicing virtual mixing
Does anybody has a 16 track Qu-16 recording of a band, that can be used for practicing mixing and play around on the Qu-16 to discover the influence of different settings and presets on the sound. It would be nice if A & H provides a “perfect for practicing” recording for download on their website.
Good suggestion
You might find something that could be useful here:
https://www.cambridge-mt.com/ms-mtk.htm
Note that this site is not affiliated with A&H in any way.
Cheers
  • Jeff, A&H
Thanks a lot and sorry for thanking you so late. I will start to look into it. It looks great.
check all tracks after downloading and make sure they are 48k 24bit MONO and convert them if needed otherwise you may have issues loading your project in QU. I have spend quite some time with errors when loading such a project which was caused by one stereo track. You also need to rename tracks according to the manual provided with your QU.
I found that tracks do not have to be same size but I have recognized quick pops after a track wave reached the end.
Track name number corresponds with channel number, do not forget to change source to USB.
Project can be set to repeat play what is good for practicing. There is no way how to cycle selected part of a project AFAIK. This would be very handy (for example virtual sound check of a solo instrument playing few bars only).
That’s just my two cents.
Pavel
Can someone upload such a multitrack-file (to the user library) who has already tested it with his Qu-16? I’m not a studio guy so would take a lot of time to download a track from the link above and change length, name, format, etc… i just wan’t to check if i could play all the tracks back! ;D
Please use for your personal educational use only.
Audio courtesy of local band Grace Notes.
Not to be distributed.
https://109.203.103.60/tech/Qu-16/AHQU.zip
Nice one!
Hi everyone,
check out this page as well.
https://www.mixoff.org
Have fun!
Pavel
