Hi, I am user of a SQ5 and I’ve noticed that when you go to the meter page, and then “Mix Metters”, the dB (-40,-30,-20, etc) of MainLR and Matrixes is not aligned with the grafic.
Sorre for my english, I am from Argentina.
Thank you
Thank you
You’re right - and the same applies to all FX send and return meters, by the way.
This wasn’t the case in the past and probably happened when someone, while adding the source point selections, simply shrunk the already neglected level meters even further.
But we should be glad that there is not also only one point that changes the color (called: “Chameleontic Channel Metering”). ![]()
