A virtual fader in the processing view plus the ability to select any channel
I think sometimes we might want to control channels which are not assigned to any bank/layer.
Ability to select a channel from the touch screen and a fader volume control using touch and turn would help to achieve that.
Behringer Wing has it, just sayin’ :wink:
Beyond that, it would be really useful for something like the C1500 where you have only so many faders & layers & softkeys…
Being able to add an input or output processing channel without having to put on a surface would be nice.
i’ve been solving this for a long time in all my showfiles like this:
i create two DCA groups for all inputs, one with the inputs 01-64 and the second with the inputs 65-128.
so these are two faders in a lower layer, with which i have access to all inputs via the spill-function, without having to put them all on the surface. a small functional help. :wink:
the same can be done with outputs, here even a single DCA is enough.
and don’t forget to set these DCAs to 0dB! hoho… :slight_smile:
