AB-168 and QU attached to SQ at the same time?
Is this possible? Will it become possible?
Usage would be split FOH/IEM monitor situation.
I have QU-sb and two AB-168 currently.
Hmm, let‘s think about it. You connect the dSnake Connector of the SB to the first Ab168, then the second Ab via cascade to the first one. Now it is not possible to connect another device to the cascade port of the second AB. Ok, and how would you connect now the SQ to the SB? Hmmm.
You will need to wait for the SLink card for the SQ. Once you have that, you can connect both AB168’s to the SQ and connect the SQ to the QU-SB, routing all I/O from the SQ to the QU-SB, with the QU-SB set as the clock source on the SQ.
Here’s the video on how to patch both systems.
https://support.allen-heath.com/index.php?/Knowledgebase/Article/View/1188
