AB168 rack mounting
are there any pictures of the rack mounting option for the AB168? How is it mounted, what about the connections on the side?
Best regards from Germany,
Toby
It’s asymetrical mounted to leave space for the connection! But it’s rather made for on-stage without case!
Is your idea to protect the AB168 while transporting? May I suggest you buy a case it slips inside of without mounting. There will be no need for padding inside this case. It will be cheapest and you get all the intended benefits of its design.
John
@John-S
It’s about protection, storage and handling. I would prefer another AR2412 but you cannot connect more than one in one (GLD) system :wink:
@eotsskleet
Thanks, I will go with the rack mount solution as there seems to be enough space for the side connections.
