ABCD source trigger for PLAYBACK REDUNDANCY
Hi all! Currently using for Redundant Playback two synced PCs (connected through Dante) running in separate channels, main PC is with PILOT TONE, Ducker is opening redundant channels controlled from sidecain of PILOT TONE.
Everything works ok, with hardly noticeable interruption in audio between changes.
But if it would be an option to trigger ABCD source from gate or ducker it would be faster and more fluent probably less noticeable. Its the most cost effective redundant option with no extra hardware involved
Info the same thing. I agree that a way to automate the switch to a different ABCD would be great. The way I want to do it is via actions. If we could trigger actions from input level (when input in a specific channel is over a set threshold) then we could use actions for this.
Takes extra hardware, but as best I can figure out the closest to what you want that can be done today is to setup a 3rd computer to monitor the pilot tone and send a MIDI command to the dLive if the pilot tone goes away.
yes trigger for Actions from input level is grate and in such case i would add GPIO for Action triggers, i dont know witch method is faster just trigerring the ABCD of trigerring Actions
interesting but to complex to be safe.. and it needs also redundant PC for control, so it takes totally 4 PC’s, two for playback and two for control :slight_smile:
