Accidentally pressed Go on scene on Dlive C3500
Hi
I accidentally pressed “Go” bottom on Dlive C3500 twice, and I pressed Prev bottom. However, nothing happens to the original scene. it changes all the the scene or over write the previous scene. How do i go back to the original scene before i pressed Go on Dlive C3500?
is there anything that i can do to undo or change the settings to its original scene without overwriting?
Sincerely,
I think the confusion lies with the fact that the “Go” and “Prev” buttons will always follow the scene/cue list order. The system doesn’t track whatever scene was loaded last and recall that scene when the Prev button is pressed. It will always load whatever scene is located in the Scene/Cue list that is just before the scene that was loaded with the “Go”.
If your scenes are “out of order” and you want to reorder them into a more logical workflow, you can use the Cue List functionality for this. Cue Lists allow you to create a custom list with only the scenes you need to use for a specific event, and put them in the correct order so that Go and Prev work as expected.
Also, just in case I misunderstood the OP, loading the Prev scene is not the same thing as reverting the console back to the last state the console was in just before you pressed the “Go” button however. If you are looking for that functionality, you need to use the “Undo” functionality in the scene system. You can “undo” a recalled scene and revert to the state the console was in just before the recall by holding down the “Reset” button and pressing the “Go” button again. There is also an on screen “Undo Go” button located on the scene management screen (to the right of the on screen “Go” button) that does the same thing.
Here is a link to the section of the user guide related to scenes. You might find a lot of functionality that you were not aware of. https://support.allen-heath.com/hc/en-gb/articles/39796743431697-Scenes
