ACE Aggregation (un)Healthy?
This started out as an occasional ‘red cross’ on Surface Link / Net Bridge on the home screen of my 144 surface. (Dual rack system: iDR-32 master, iDR10 slave)
I saw today that Mix Rack 1 - Mix Rack A - Port A (under Mixer Preferences → Port A/B Setup tab) shows a ‘red cross’ on ACE Aggregation Healthy as well.
Should I be concerned? There is no noticeable problem with audio nor are any errors logged anywhere, but it is a bit disconcerting seeing this every 3-20 minutes…
RayH
Hi RayH
This indicator is activated if the network bridge between surface and stagebox has to drop a control packet due to the ~9 megabit/second bandwidth limit on the net bridge. Dropping the odd packet does not matter and should have no noticeable effect, as the TCP/IP protocol used will automatically resend the packet. If you do not notice any problems with the operation of the desk, you can safely ignore this.
Hope this helps
  • Jeff, A&H
Good deal. Haven’t noticed any problems associated with it so I’ll ignore it until I do.
[:smile: ] RayH
