I’d like to have the ‘Sel Mix PAFL Scene’ softkey function available in actions so you can simultaneously listen to a mix, select the mix (what this does) and also recall a certain strip assign (when using split channels for FOH and MON on 1 console). Go to the mix + recall the surface layout in 1 touch in stead of 2. When pressing the same action again you can toggle back to the FOH layer using the toggle function.
+1 ?
+1
This would be nice. Combine that with toggling a specific talkback group and I’d be a happy camper.
The scene will already store and recall the strip layout.
Sure, but I don’t want to recall a scene. It’s only a workaround to be able to select the aux as well as immediately PFL it as well as activating an action.
