Active Stylus partly does not work in Mixpad
Using convertible 2-in-1 laptops, in Mixpad, an active stylus can be used to control input elements of the remote control software.
In this way, the SQ can be controlled via Mixpad software much more comfortable, because active stylus works more precise and more sensitive than fingers or passive stylus.
However there are some elements in Mixpad, which cannot be moved with an active stylus:
  • fader strips in Processing View
  • GEQ faders
  • PEQ points
Tested with
  • ASUS Vivobook Flip with Win11 and ASUS active stylus.
  • HP Pavilion x360 2-in-1 with Win11 and HP active stylus.
A pen should work with all control elements of Mixpad graphical user interface.
Have reported this issue to the A&H support.
I can also confirm this behavior (with ASUS).
It only seems to be in areas where multi-touch functionality exists, e.g. multiple faders can be changed at the same time or the width in the EQ can be adjusted with two fingers.
So I suspect there is a connection.
