I was very positively surpised by the spaceverb, however I really would like to see pre-delay added this reverbs.
I can’t imagine somebody would need 583ms of delay on the output busses, so I think the delay memory would be spend wiser on a pre-delay of the reverbs.
The regular output buses have nothing to do with the UltraFX.
And there is already a Pre-Delay parameter available.
I can find the pre-delay parameter for SpaceVerb, can you tell where ?
Image doesn’t look like it is from the CQ…
OK, looks like STeffenR confused about mixers.
I +1 this feature suggestion.
You can set and test a pre-delay setting for any verb FX easily with the CQ:
-under FX tab, set you FX Level to LR OFF.
-under Processing/Reverb/Sends, set you FX to go to on AUX Out (OUT 1/2 in the example shown).
-under config/outputs, select you AUX Output Delay to you desire value
-link physically (with TRS cable) your Aux Out to any free input of the CQ (Input 7/8 in my example) and use this fader to set you level of FX send to L/R.
This will allow you to hear the FX with some pre delay.
Just for fun and testing.
To clarify, there is pre-delay in the reverb/s, set by type and also included in the size/time adjustment.
So the suggestion here is to have separate control of pre-delay?
Hi Keith,
Indeed, having control over the pre-delay would give a great added value to the Spaceverb. The algorythm of this reverb sounds really nice!
