Adding/Adjusting FX on a Mix
Hello all,
I am not an advanced user by any means to please bare with me.
I have configured a reverb (SMRverb) on FX1 and it adds reverb to our mains. However, how do I get this reverb on a specific mix? For example, Mix 1-9 are IEM mixes and mix 10 is our live stream.
I’m sure this is a simple solution so thank you for your patience.
Ben
Select on of the mixes by pressing one of the mix buttons on the right and adjust the FX1 return fader to the desired level. This way you also send the reverb signal to a mix.
Does this mean the FX level is not adjustable independent of the main FX?
It would depend if the send is set to pre or post fade, pre fade it would be independent.
If I change it to pre, the downside of that would be the reverb effect would still be present if I bring down a fader on the LR mix.
Correct?
