Adding new possibiliies in Fx Back Panel "Patch From"
I regularly use a mix of classic effects sends and aux sends for effects.
I think it would be practical to be able to freely select the FX send bus to the desired processor.
Currently, it’s fixed: mono FX1 sends to FX1, mono FX2 to FX2, etc.
It’s a logical way of working, but if you want to make a change, it requires more manipulation.
Cheers,
Florent
You don’t see that drop down? :thinking:
Or what else is the point?
Yes, I know that
But like you can see, in Fx1 proc you can’t choose Mono Fx 2 bus or 3 or,… only Mono Fx1
Why should I want that?
The FX sends are the inputs of the corresponding FX device.
Why wouldn’t I want that? :wink:
For example:
If you use an aux instead of the Fx1 bus send to send to the Fx1 proc, the Fx1 bus send is lost; you can no longer use it for another Fx proc.
Sometimes I want to keep a chronological order of my auxes in the order 1, 2,… to the Fx procs and also with Fx sends, but that requires starting with something other than number 1.
Finally, a workflow suggestion… maybe not interesting, maybe yes.
