Addition of individual LR adjustment of output delay value.
Would it be possible to improve Avantis so that the Delay value for the stereo Bus (Group, Aux, Main, Matrix) for each output can be set separately for L and R?
Currently, LR can only be set to the same value. This is a difficulty when equipment or seating layout is asymmetrical situation.
This feature would also be useful in the approach of using delay to create the sound image without PAN, when the inputs are once routed through the stereo group and output to Main (L,R).
It would be great if you could support this in the version update.
Thanks.
If you have a spare FX, insert it as the Stereo Tap delay, unlink the L/R in the FX, set the mix to 100% wet, no feedback and open up the frequency response and set the time to milliseconds. Then you can use this to set a different output delay to each L and R. You can also use this technique to get output delays much longer than the standard output delays, in case you have delay speakers up to 2000 metres away.
Go into Setump → Config and change the main from a single fader to individual L/R faders, and you will get separate delays.
Unfortunately, for all Stereo Aux and Stereo Grp, it is not possible to solve the problem by setting the Fx remainder or Main L/R fader strip settings.
I look forward to the update.
