This may be a basic or dumb question but I’ve yet to find the answer. In order to ring out a feedback it’s always been customary to be in the eq screen screen and be able to bring up the level to the ring point. Adjust the offending freq either by ear or looking at the RTA. I cant see how to do this. What am I missing? I cant find a way to do that.
You can use CQMixPad or MS to achieve that.
You will have two different screens to control your inputs.
This should be a basic thing. Can do it on any other mixer. The channel fader should be available in the selected screen.
I have the 12T and I can’t adjust a chanel’s fader while in the GEQ or PEQ.
I need to have extra tablet or midi controller.
Maybe with the 18T and 20B soft rotaries can manage that.
Shouldnt be like this. Needs to be in a maintenance fix should have been there in the beginning
I have a pretty good work around for the time being. With Custom layers now available, simply put MainLR on as many of your input layers as you would like. now there’s no frustrating going back and. forth. Further, If you don’t want the MainLR showing up there the whole time you can simply toggle between regular layers and custom layers as needed. ![]()
+1
The request is to put level in the eq page (processing), seems reasonable, as changing eq can mess a lot with perceived level!
