I had made a start scene at home without stagebox connected before a show.
At show I hadn’t have good input levels, after check I saw all Trim are at -24db…After set to 0 sound good.
I have checked again and noticed that :
- when stagebox (AR2412 & AB168) are connect adjusting gain do not change trim value.
- when stagebox aren’t connected adjusting Gain change also the Trim value…
Firmware 1.3 & 1.4
In my case I had set all gains at 0 but haven’t saw the trim values changed…
For the next firmware update probably you can change this.
One error source less ![]()
Best
