After 1.50 update: CC does not display AHM values correctly
I tested it with an AHM64 and an AHM32:
the AHMs work perfectly - but the input levels are not all displayed correctly in the appropriate file for CostomControl.
There are input level indicators on channels that are definitely not getting a signal.
The output levels are obviously displayed correctly.
The inputs come into the two AHM devices via the Dante card.
I have reset the AHM back to V1.43
Quite interesting!
What are the meter pick points?
What sort of metering is happening on the channels where there should be nothing?
And, which version was that CC config built in?
Hello Samatha,
The meters show the input levels of the channels. I have taken a meter for each input in the CustomControl-editor and defined the corresponding input in the editor.
For example like this:
Channel Type= Input
Channel Number = 3
Meter Type = Post Preamp
The CC version is V1.41, i.e. the latest version.
With AHM firmware version 1.43, the inputs of the channels are displayed in CC as I have defined them.
However, if I load 1.50 and load the same file there, these levels are sometimes displayed on other meters.
I have not changed anything in CC and AHM, just a different firmware version in AHM.
I tried it on AHM64 and AHM32, with different configuration files.
I hope you can reproduce this. Otherwise I could send you the files
Hello, are there any findings on this?
I would like to update my AHM controller to 1.50, but I can’t do that as long as the wrong levels are displayed in Custom Control
This was reproduced here and a fix will be coming in the next maintenance release. Thanks for reporting it.
For reference:
AHM 1.43 with CC1.4.1 is OK.
AHM 1.50 with CC 1.4.0 is OK.
AHM 1.50 with CC 1.4.1 has the issue above.
Hello Nicola,
thank you very much for the feedback!
