After 5+ hours Qupac audio starts crackling, popping
I uploaded example: https://youtu.be/bTUeKhI0k3Q
Sound comes from headphones out.
Feels like some processor is overloaded.
It does not matter what I do or which channel I PAFL. It becomes totally useless.
Crackles comes like waves - at the top of the wave the sound disappears almost completely, then again crackling will go away and quietly start to come back again. Switching the device OFF/ON does not help. Also, device is not hot, at least I don’t feel with hand. At the same time these cracklings were not recorded (multitrack). They are audible only in headphones and monitors.
And I don’t use FX at all.
Also seems that if I just leave it ON, lets say whole night, then it works fine. But if I really use several channels, do multitrack recordings etc then it starts to happen.
What should I do?
Do you have anything connected to the analog inputs on the mixer.
Look at the utility menu and see what the operating temperature is.
Yes thats really weird.
Check what Mike C says …
And is there is NO computer plugged in?
And is ST3 turned right down?
Yes, 1-16 line inputs are all connected.
No computer plugged.
St3 turned off.
Latest firmware.
Ok, I will check temerature next time when it happens.
In the video where is the playback source coming from, the analog inputs
or from the USB Q Drive.
Do you have the phantom power turned on any of the analog inputs
Please also make sure the FX are definately turned OFF everywhere. Failing all of what Mike has asked. Maybe you could do a hard reset back to factory settings?
