Hi, if someone can help.
The meters on the inputs shows only post preamp. I need it to show after fader. I wonder if this is a bug or there is a setting that needs to be set.
Thanks.
Thanks.
Tried to find the settings for that, but unfortunately seems A&H made it work that way only. Input meter just copies the Preamp meter.
Hi both,
The channel meter shows post-processing, pre-fader metering for Input channels, but post-fader metering for Mix channels.
You can check the post-fader level if needed by pressing PAFL on the channel, with the PAFL set to AFL.
