AHM - SQ5 Audio digital vs Analog signal difference
This is a little oddity I found and wanted to see if anyone had any insight.
I am using an AHM64 as a system processor and have been sending audio analog from my SQ5. I just received an S-link card so I can send the signal digitally. I found that once I patched it digitally there was a 5db drop in the signal. I have been running some level test and learned that in fact the analog is boosted 5db. Is there a reason for this. I and doing nothing but changing the routing, no change in processing. it’s not creating any issues, it was just strange.
Anyone have any ideas why?
Seth Wiese
||Schematic of signal chain||
Analog : SQ5-(SLINK)-AR2412-(DSnake)-AB168-(XLR-Phoenix)-AHM64
Digital : SQ5-(I/O port Slink)-AHM64
Hi Seth,
Most pro audio equipment historically used +4dBu as a nominal output reference (with meters at 0) for better noise performance over analogue cables. +4dBu is also the nominal output level for SQ mixers. When connected to an analogue input with 0dB gain, this will translate to +4dB of gain in the system, so what you are observing is expected behaviour.
Awesome, Thank you!
