AHM64 - Priority input using internal player only sends left channel to output
A client made a setup where he would like to use the internal playback to play a song with priority input so that all other inputs get muted.
When using the priority input option, it only passes through the left channel, even though i can see the playback is stereo.
So at the venue only the left speakers will playback the song.
I’ve tried different stereo files and formats and the problem seems to be consistent. I’ve attached a screenshot of the problem.
Is this a problem that someone else also experienced and maybe has a fix for?
Thanks in advance for the help!
Fixed it with embedded recall and delays, so its working now.
Still it would be better to have the priority input working in stereo, because of the maximum delay time of 4 minutes.
