Allen & Heath Xone DB4 firmware Version 2.2.3?
Have seen a few post with peoples Allen & Heath Xone DB4’s operating firmware V2.2.3?? Last update on there legacy hardware DB4 support page is for V2.2.2 in 2015, which I am currently running (https://www.allen-heath.com/ahproducts/xonedb4/). Can anyone link me with this update and/or tell what improvements were made from 2.2.2 to 2.2.3??
Good question!
Hopefully they fixed the firmware so that more than one cue selected at a time will bypass split.
Having a selectable internal work sample rate instead of being just fixed at 48khz would be a bonus.
I also think they should add another two models to the DB lineup.
Al Crombie
Conan Neill xonedjofficial replied to you back in June when you asked them. maybe that was lost to your spam folder?
for info.
v2.2.3 was a maintainence iteration of v2.2.2. It accommodates an updated screen component used on the mixer.
If your DB4 is running v2.2.3 it’s up to date
If your DB4 is running v2.2.2 it’s also up to date, it’ll just be slightly older hardware than a mixer running 2.2.3
In practical terms, as far as feature set goes, v2.2.2 is the ‘latest’ and v2.2.3 is ‘the same’
My response:
Benjamin W. Goulart
Al Crombie Thanks for this. Why the didn’t A&H ever allow us to bypass split cue with more than two cues selected at a time? Burying split cue in the settings without a button was a mistake, but there was a firmware solution. For that matter, the line needs a 3 (4 or more rear channel inputs) & 6 channel version using the dLive kit.
Sorry, meant to say “more than one cue selected at a time”, but ran out of editing time.
