allow IP8's mix faders to swap to sends when channel's mix button is pressed
I assumed the IP8 would behave in the same way as the console. Sadly I was wrong.
It would be super helpful to me if I could have (for instance), all my monitor masters on the IP8 and whenever I would press the mix button of a channel on the desk, the monitor masters on the IP8 would swap to that channel’s sends to their respective mixes, just like they would on the Avantis.
Please make this possible! Thanks.
Yup. I felt duped when I received my two IP8s. I really hope they can add this in.
So I was literally just about to order an IP8 to use for a surfaceless setup. CDM32 onstage, IP8/Laptop/Network switch at FOH. This calls the whole setup into question, and I can’t seem to find much information on actually using the IP8.
I am using 2 IP8s in a surface-less setup. Sends on fader is absolutely doable, although it takes a little bit of programming.
I understand that a “native” solution would be easier to handle, but IP8s are absolutely useful for that task. Working with that setup for over 5 years now (8 Monitor mixes from FoH), and I am not looking back.
I am using 2 IP8s in a surface-less setup. Sends on fader is absolutely doable, although it takes a little bit of programming. I understand that a “native” solution would be easier to handle, but IP8s are absolutely useful for that task. Working with that setup for over 5 years now (8 Monitor mixes from FoH), and I am not looking back.
That’s encouraging to hear! Placing my order shortly.
