So this question keeps popping up in my mind and I’m wondering how you guys are dealing with this.
I want to add two analog distressors to my sq5 for lead vocals, but I can’t figure out how to do this.
All the forum messages are linking this video where the guy just uses Mic Input 1 and Line output 1 locally on the SQ5. While I can understand the Line Output 1, I’m puzzled why we ever want to use a mic input on a mixer to an analog Line output of a compressor.
I don’t want to use a mic preamp in my line signal chain of the compressor.
people are saying to use the pad, but I don’t want to risk phantom power going directly in my distressors. That would destroy them.
Just being careful isn’t an option. I’ve got a lot of shows I load without knowing for sure if the mic input on the SQ has phantom power or not.
all my line in channels on my SQ are already in use.
So how are you guys dealing with this? I don’t think using a mic preamp is a professional and safe way to use as an insert for analog gear. It’s weird I don’t find the correct way anywhere online.
If all your line inputs are already in use, you don´t have an other choice than to use the XLR ins. If you are concerned about phantom power you could maybe use the radial IC-1 ice cube isolators. They should block 48V from going to your device. But please, read it up for yourself, in case my informations arn´t right.
Yeah, I think you are on the right track. Not an IC-1, but a DI box should do the trick. I’m just wondering why everyone on the internet is advising to use the direct Mic input on the desk. And if there are people out here doing it differently and having good results.
When you are using the local input sockets as insert return points there is no pre amp connected, the signal is automatically routed with the existing channel. Thus there is absolutely NO CHANCE of phantom power appearing at that socket.
Unfortunately, that’s not true.
Every local XLR input is always inextricably linked to a preamp and so it’s certainly possible to supply phantom power to an insert input.
Moreover, patching a local input to an insert doesn’t automatically remove a maybe existing patch to an input channel.
And you could also subsequently patch it to input channels, so there remains the risk of activating phantom power there as well.
