I recently upgraded from an SQ5 to an Avantis Solo, and I’m trying to keep my setup as compact and lightweight as possible.
I’ve already invested in a Scott Dixon case to save weight and space, but I’m still looking for some smart additions to my setup.
For example:
Wi-Fi: I’m looking for a compact router/access point with excellent range and reliable coverage around the venue.
Dante multitrack recording: What’s the most compact and reliable way to record multitrack over Dante without carrying too much extra gear? I feel like a Macbook Pro with Dante Virtual Soundcard is the way to go.
But I’m also curious about things I haven’t thought of yet!
So, for those of you who use the Avantis Solo: what accessories, tools, setup tricks or workflow improvements have made your life easier?
Same here. Also bought the Scott Dixon case. I‘m using an Gl.Inet GL-AXT1800 wifi router and I‘m pretty happy with it. Works well and is pretty compact. MacBook Pro with DVS for Multitrack Recording. I taped power cable, network cables for Dante and remote control and mic cables for Talkback and measurement mic all together and carry them with an dual USB-Charter (MacBook & router) in a little bag…
I second the idea of using a “travel router” from GL-iNet. They allow you to create your own private network (wired and wireless) while also connecting to another network (again wired or wireless) for internet access if needed. Most other all-in-one routers allow you to create your own wireless network, or connect to an existing wireless network( bridge mode), but not both at the same time. The GL-iNet travels routers allow you to do both at the same time.
As far as recording via Dante, I would also recommend using Dante Virtual Soundcard. The regular “cheap” version gives you 64x64 which is perfect for multitrack recording on the Avantis. If you need a higher channel count, you have to step up to the “Pro” version which has a subscription fee instead of a one time cost like the regular DVS software.
That being said, if you don’t already have a Dante card and you are looking for primarily a multitrack recording option, I would highly recommend getting a Waves card instead of the Dante card. It is cheaper, and the drivers/software needed on the computer side is completely free - even up to the full 128x128 capacity of the card. That’s certainly a much better option than paying for the Dante DVS Pro subscription cost every year if you need more than 64x64.
Yes, it is so. for Avantis is recommend DAW Live Trax, with Midi Control. Then you have Possibility to Transfer Channel Names to the DAW. Or Scene switching. But only Work with Mono Channel for Recording you can Gang for Stereo Features alternative in Avantis
You can Migrate you SQ Setup over the Mixing Station App over MS Scenes.
It should i have tested it from X32 to Avantis, and GLD Avantis. So you have over 90 Percent Migrate. But it is recommend to Go through all Features of Avantis.
the folks at StageStrike made a nice 3D printed shelf that fits on the top; folds flat with hinges for easy travel but gives you somewhere to put a laptop. I just got mine and it’s great.
I also have two of the Allen & Heath removeable tablet brackets so I’m all decked out with a tablet and some velcro to hold my IP8 in place.
I keep a 4U rack at FOH that includes a UPS and a POE switch which powers my IP8, and through a fancy adapter it provides power over USB-C and network connections for my GL iNet router. I have the Dante I/O card so I use DVS for multi-channel recording or VSC, my Smaart rig, and drive lines to my amps and processors.
I configured my IP8 with the first bank as all DCA’s with spills active. I have a DCA spill that shows me all the FX sends and returns, one for all my Mixes, I have another that’s just labelled “all inputs” so that if I plug a random thing into a random place in the system and it’s not mapped to the surface I can find it quickly and patch/unmute. DCA’s really help increase the number of fader layers. I had a complex setup the other day for a band with 32 channels from stage but the opener only needed 15 inputs. I used the same scene and just modified a few settings (shared drum kit) but now all their inputs were spread across 4 layers. I quickly assigned that opener bands inputs to a DCA and mixed them with the DCA spill active so they were all on two layers; saved me changing the layout between acts.
I use some small crab-claw style clamps with mic-clamps for my measurement mic (grabs the side handle on the solo nicely) and talkback mics. The GL iNet is nice, but I also have a mesh access point in my amp racks so when I get to stage I can stay connected with my tablet.
