Any way to undo delete?
I don’t know how it happened but it did. I accidentally hit delete. Distracted for a second as I was about to archive a show on my R72, I looked down to see my user show directory disappear with all my shows. I definitely got lazy with backing up to thumb drive.
Probably a silly question, but is there any way to undo delete?
i don’t think there is a possibility to undo delete! However, for a new console that would be amazing! either a “log” like at the AVID consoles where you can easy jump back to earlier timestamps or something like the “oooops” Button of the GrandMA for undo command! ;D
If you deleted it from the flash drive you can probably get it with Recuva:
If you’ve deleted it from the console the same thing would work, but you’d need to pull the drive so it’s unlikely to be worth it.
Chris
