The App did not Show All
Tested on Some Android cellphones
Hi @rottmat
Please tell us more about your setup, which mixer you have and are you trying to connect via the built-in wi-fi or an external access point?
For the app to show and connect to the mixer, your device must be connected to the correct wi-fi network.
If you need technical assistance with this, please reach out to our Support team at support.allen-heath.com
Usually (I’d say 99.999999% of the time) when the app doesn’t see the local console it is because the mobile device and the console are not on the same network. Perhaps the phone is using a cellular connection and wifi is turned off, or the phone’s wifi was wonky and a reboot fixed it.
As far as the slider on the right side, that is obviously a “resizing issue” with the app. The app is suppose to resize itself automatically because every device is going to have a different screen resolution and the app should work with all of them. You should submit a formal support ticket (from the main A&H website). This forum is not “official support” although the A&H team certainly monitors the posts here. Hopefully A&H can fix this, but you might try changing the screen resolution if it really bothers you.
My request concerned only the resizing.
I hope a&h fix this asap, the 20b is unusable
Hi @rottmat
CQ-MixPad is primarily designed for tablet use (and there will also be macOS and Windows versions available soon).
With Android, there are far fewer conditions on minimum widget size, so they will let the app run on android phones too.
It does seem that a surprising number of users are wanting to do this, so we have logged this as a resizing bug and hope to have a fix out soon.
Hi@ Keith!
Tanks!!!
