Are GLD midi strips bidirectional
Reading various bits of documentation it hints that the midi strips are bidirectional ( as they seem to be on the QU) I.e. When you move the GLD control it sends the configured MIDI message, AND when the GLD receives that message it changes the midi strip accordingly. E.g. Sets or clears the mute LED, or moves the fader.
However, I haven’t been able to get this to work. It’s possible I am doing something wrong, but also possible that it is not supposed to work, despite the documentation hints!
If that is the case, it would be helpful to know to save me trying to figure out what I am doing wrong.
Thanks.
Mike
So I can answer my own question. Yes they are bidirectional, BUT in the case of setting the rotary gain, while it does update the actual value stored in the strip it doesn’t update the display in the LCD until you either move the knob slightly or switch to display pan or one of the custom values then switch back to gain. Not too much of an issue, but it led me to believe that setting a value in the GLD via midi wasn’t working.
Setting the fader level works fine fortunately.
I haven’t tried any of the others except setting the mute LED which does work, so this seems like a reasonable work around to the problem of not being able to independently set the local/non local state of the three buttons, since you can leave local off and then set it remotely in response to pressing the button.
All good fun :slight_smile:
Mike
Hi Mike,
realise this was written quite a while ago now but I’m just in the process of trying to wrap my head around precisely what it looks like you cracked! Specifically how did you get the Mute light to work without setting it to local or using Mackie Control. Any help much appreciated! I’m trying to map GLD to Logic X so for example when I have Midi Control set to Midi Thru assigning the mute button works but the LED won’t light. If I switch Midi Control to Mackie Control the mute button works and lights up but then I can’t assign Pan and the other three rotaries.
Dan
Hi Dan,
Wow! That’s a long time ago, and I really can’t remember, or even understand my own post!
To give you some context, I was writing a python program running on a raspberry pi to interact with the GDL via midi. My memory is very hazy, but looking at the code it seems to be the case that pressing a mute button on the GLD sends a midi message saying it has been pressed, but doesn’t change the setting of the mute light on the surface, so what I do when I receive a mute pressed message is perform the actions I want, and then send a message back to the GLD to toggle the state of the light.
The midi configuration of midi channel 1 mute switch is
91,00, local OFF
i.e. local is off. Hence pressing mute doesn’t change it on the surface.
See this snippet of python code in case it is any help at all.
elif m.type == ‘note_on’ and m.channel == 1:
if m.note < 0x20:
# MUTE
strip = m.note
if m.velocity >= 0x40:
print(“MUTE ON”, strip + 1)
# toggle the current mute setting for this channel
newMute = not lights[strip].getMute()
lights[strip].setMute(newMute)
# and echo it back to the GLD
sendMute(strip, newMute)
and sendMute is defined as
def sendMute(strip, muteOn):
“”" Send midi strip mute setting message to GLD.
MUTE ON send velocity 127
MUTE OFF send velocity 0
followed by note off
if muteOn:
    vel = 0x7F
else:
    vel = 0x3F
muteMessage = Message('note_on',
               channel = 1,
               note = strip,
               velocity = vel)
gld.send(muteMessage)
muteMessage = Message('note_off',
               channel = 1,
               note = strip,
               velocity = 0)
I hope this might be of some small help to you, but I rather suspect not.
Mike
