ASIO driver problem?
Hello. Before this a couple of screenshots about my system.
Here a vid that clearly shows the error
https://www.instagram.com/p/BccxF20lrpc/
I asked this before in acustica mixcraft forums and tech support.
Their answer is:
“Hi, your latency is 42+ms, have you opened the asio software and lowered that?
What you are experiencing is an asio driver issue, not Mixcraft.”
Tryied with USB 3.0 and 2.0
Tryied with no ASIO drivers with similar results.
Don’t know what else to do.
That’s a loop, not latency …
Have you tried any other sessions in your DAW? Do they play correctly? If so, then you have a corrupted session file.
Hi all, after trying a lot of different options, finally the problem was because this freeware plugin
https://www.vst4free.com/free_vst.php?id=1329
Maybe only chrash with mixcraft8 maybe with other DAWs, but that was the problem
Solved converting the virtual instrument in an audio track and deleting the vst track.
Now works GREAT! with very low latency.
I just post here if there is somebody with the same problem.
thanks.
