Hi there!
I use multitrack playback on QU-SB with QU-Drive.
I export tracks (TRK01.WAV … TRK18.WAV, 24bit/48kHz, mono, same length) from Cubase LE AI Elements 10 (without iXML chunk or another flags, don’t use wave extensible format), place their into \AHQU\USBMTK\QU-MT001 folder on flash drive and get “Invalid project” error.
After that I do same tracks in Cubase 5 (with same export parameters and naming), replace files in QU-MT001, and all working correctly.
Have anybody ideas why so? Maybe I forget to do something important before export from Cubase 10?
I don’t have either Cubase version, but I can make a suggestion. I attempt to solve most problems by Process of Elimination.
It may be a problem with only one WAV file. With the Cubase 5 files on the flash drive and working, copy/replace only one file at a time, testing them on the mixer each time between file copies.
If you are certain that all parameters are set the same in both versions, then perhaps a file-compare utility/app can find what is different between flash drive copies.
Sorry I couldn’t help more. Just giving you food for thought. Good luck.
