Caution, mildly pedantic post
So I set up my SQ5
‘Setup’ - ‘Mixer Config’ - ‘Bus Config’
‘Number of groups’ and ‘number of auxes’
Next is my Strip assign
‘Setup’ - ‘Surface’ - ‘Strip Assign’ - ‘mix’ (not totally sure why we switched to mix when we had bus a moment ago)
Groups first, then Auxes.
All good so far.
Go to use the ‘Mix Select’ buttons down the side of the console.
Groups first and then Aux right? WRONG! Its the other way up! Admittedly it is the way up I would expect it to be, if you hadn’t let me on with groups first everywhere else on the desk!
Its probably too late to fix this now it was just one of those things that was annoying when having this desk out for the first time.
