Aux Bus Library
I would LOVE the ability to set mix presets. As in what channels are assigned to a mix and at what levels sent, and pre/post.
This is great for monitors too! It would make it easy to maintain a default mix.
Are you talking with regards to a FoH or monitor context? Is there a reason that a scene wouldn’t be ideally suited to this purpose for you? Scenes do have the ability to recall mix assignments, send levels, and source points. And of course, this can also be done for Main LR. Not an apologist, so don’t take this as me suggesting your feature request isn’t worth while. I just don’t think I fully understand the problem you’re trying to solve.
Just a simple preset library for Mixes that recall all that is being sent to the mix and how.
When you hit Copy + Mix, that’s the data I want to be able to save as a preset.
In some way A&H was close to this by allowing Channel libraries to save their sends. Now, I would just love it to go the other way.
Snapshots can do it in a more convoluted way, but then you have to go in and adjust the filters to only effect which busses you want to be effected. That’s pretty clunky and inefficient in a field where speed is often a necessity.
Does 2.0 not do this?
I tried it on Director offline mode and was able to save a mix from the Library page, make changes, and recall it.
For our purposes this would allow me to save Drummer X’s mix, then load Drummer Y’s mix when he plays, and so on.
Go to the Aux page and choose library. Routing is now an option on the recall list.
Indeed now possible with 2.0!
Ugh. Weird. It wasn’t showing for me yesterday. But it is now!
I think my error here may have had something to do with changing from “legacy” presets to current preset saves. Interesting. And noted.
