Aux Pre / Post
By default all auxes are setup to be post fade.
We only use pre fade on our aux busses what means that every time we set up or change a bus we have to switch from post to pre.
  1. Who uses post fade on auxes and why anyway?
  2. Wouldn’t it be quicker to have pre fade on default?
  3. If we agree with eachother a bigger crowd is more likely to
get Research and development to change the default, or add an option to change the auxbus default settings to prefade
Jeffrey Vermunt
Sound Services
Jeffrey Vermunt
Sound Services
1: Dancetracks, VB’s, stingers and fanfares etc that also need to be on stage are best post fader. Imagine you are playing back a contentum for improvised theatre, the part is over and you fade out the contentum, unfortunately you are pre fader and the sound continues on stage. Not good.
2: For my day to day use I believe yes, faster with prefade as default!
3: Option to change the default settings would be gtreat.
IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express
Hi
In reply to Jeffrey V;
1.We only use auxes in pre fade mode, exept for FX and soundtracks,
as scruffyd says,only then these channels are best set in post-
fade.
2.It would defenately save time if all channels were pre fade.
In our configuration most channels are ,and only few in post-fade.
It’s faster to set a few channels from pre-fade to post-fade,than
almost every channel from post-fade to pre-fade(no rocket science).
3.I’sure hope R&D will read this topic and change the aux default
settings in standard pre-fade,this would save us a lot of time
alltogether because we use three different IDR Racks
This is a usefull topic,I hope everyone will read and reply on.
Thank you Jeff
Regards;
Peter
xxxx
Hello Woutert,
Most of us know how to use I-Live equipment.
We all know we can alter things to our likings.
But it would be faster to start with all auxes in pre fade mode,
so you won’t have to alter post to pre to start with.
I must have missed something in your earlier respond to Jeffrey I suppose?
Why is post fade safer as a default?
Regards;
Peter
xxxx
I agree on the fact that pre is easier. What I meant was that I never had a problem with the current defaults.
You mention that the problem mainly arises when changing busses.
I think, the nicest solution would be if the rack would reload the last settings after a mix bus change instead of defaulting everything.
Now I do ‘store all’ before changing the mix config and then recall that scene which has the same effect. To me, I would like this to be the default behaviour when changing a mix bus config.
Wouter
IDR32, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
quote:
Originally posted by woutert
I presume you know that you can set pre/post for an aux for all channels at once?
As pointed out earlier, post-fade is “safer” as a default.
Wouter
</font id=“navy”>Totally agree, post fade as default…</font id=“navy”>
RayS
R-72/iDR32/iPS10
As a monitor console I always prefer post on every aux.
SRV-AVB
R-72, iDR-16, xDR-16
Yeah I’m with Ray. Post fade default is the safest and I suspect some are not aware of the global pre/post Aux setting ( Routing window)
Also I use post fade aux sends alot in conjunction with matrix sends - especially in theatre shows where you need radio mic vocals to go to orchestra monitors and backstage feeds, choir mics fed into stage monitors, orchestra feeds to stage and to backstage etc. Then scene automation fader level changes make the same proportional change in all those sends.
Cheers
Richard Howey
Audio Dynamite Ltd
Agree that post fade is safest…if the FOH channel fader is down, it’s down everywhere else too…therefore no surprises in any outputs…
Changing pre to post globally takes about 1 second so yes…also agree, it sounds like the pre/post proceedure may not be known about by first couple of posters…
Cheers y’all…
T112|iDR48+ACEcard|Laptop|iDR16|iPad|iPS10
I stand corrected! How did I miss the global pre to post? “embarrassed”
IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express
