Is there a way to simply assign an aux out to a Dante channel. We have a dual rack ilive 144.
It’s not too bad, from the outputs screen select the mix rack that has the Dante card in it.
Select the Dante card tab, select the Dante channel you want to configure, on the right side of the screen you will have a dropdown box to select the source–you will want to select “mono aux” and dial up the Aux channel you want.
I can’t seem to be able to edit the previous post, but it’s not 100% accurate… need more information on your system setup/rack config…
More than likely your Dante card is in the slave rack, in that case you will have to map your aux send to an ACE channel from the master rack to the slave rack, then assign that ACE input channel at the slave rack to your DANTE output channel.
